in reply to:
10:59 PM
- Mute
- Permalink
- Report
11-04-2018
10:59 PM
I tried a bit, but, why isn't he finding the document?
Error in rule: Rule4, in document: Assembly1.iam
iProperties:The document named "U:\temp\PTN_Part_Library\PIPE\PIPE_200011.ipt" was not found.
GetInput :
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 000000)
If Six_Digit = "" Then
Return
Else If Len(Six_Digit) <> "6" Then
MessageBox.Show("Input must be 6 digits", "ilogic")
GoTo GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "U:\temp\PTN_Part_Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
"*.*", SearchOption.AllDirectories)
For Each oFilename As String In oFilenames
If oFilename.Contains(Six_Digit) Then
Dim oOptions As Inventor.NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
sFilename = oFilename
Exit For
End If
Next
If sFilename = "" Then
MessageBox.Show("No matching libary file found.", "iLogic")
Return
End If
iCounter = 0
'trying to get the original partnumber
oOriginal_Partnumber = iProperties.Value(sFilename, "Project", "PartNumber")
MessageBox.Show(oOriginal_Partnumber)
