clutsa
I got this far but I have to do may actual job now I guess.Smiley Tongue I'm close on the sketch part but not all sketches have dependents so you'll have to find a way around that (I'm sure a Try/Catch could do it)
oDoc = ThisApplication.ActiveDocument
oFeatures = oDoc.ComponentDefinition.Features
oSketches = oDoc.ComponentDefinition.Sketches
ext = 1
iFeat = 1
'same pattern for other feature counts here
For Each oFeature In oFeatures 'look at all the features that make up the body
	Select Case oFeature.Type
	Case = ObjectTypeEnum.kExtrudeFeatureObject
		oFeature.Name = oFeature.SurfaceBodies(1).Name & " - Ext. " & If (ext < 10, "0" + CStr(ext), CStr(ext))
		ext = ext + 1
	Case = ObjectTypeEnum.kiFeatureObject
		oFeature.Name = oFeature.SurfaceBodies(1).Name & " - Ext. " & If (iFeat < 10, "0" + CStr(iFeat), CStr(iFeat))
		iFeat = iFeat + 1
	'Case = ObjectTypeEnum.k...
		'same pattern as above
	End Select
Next
For Each oSketch In OSketches
	If oSketch.Type = ObjectTypeEnum.kPlanarSketchObject Then
		For Each Dependent In oSketch.Dependents
'			If Not Dependent.Definition Is Nothing Then
'				oSketch.Name = Dependent.Definition.Parent.Name & " - Sketch"
'			End If
		Next
	End If
Next
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
