vkulikajevas
345 Views, 1 Reply
Rule - Face Area to iProperties
Is it possible to get assigned name Surface Area to iProperties with a rule?
I want "My_Face" surface value added to iProperties with a rule.
R.Mabery
in reply to: vkulikajevas
Yes, faces have an Evaluator property that in turn has an Area property that reports this data back.  If you've named it using the Name Geometry command, you can get that attributed face and then read it's area.
Take a look at the Programming Help on Face Object and it's Evaluator property.
Randy Mabery
Applications Expert
IMAGINiT Technologies
