784 Views, 4 Replies
Include 3D sketch in drawing view
I have been adding to the code for setting automated center lines so that it also includes 3D sketches in the selected drawing view. Code went together fairly easy or so I thought. I tried different methods for doing this but the outcome is always the same. Not sure what I am missing or why it is behaving the way it is. Code is below and attached is a screen shot of the outcome. Using Inventor Pro 2018.3.1. Issue is the same on Windows 7 and Windows 10. In the image the far left detail is correct. The rest has the 3D sketch coming in not properly oriented. Any help would be appreciated.
    Public Sub CMandCL(ThisApplication As Inventor.Application)
        Dim oDrawDoc As DrawingDocument
        oDrawDoc = ThisApplication.ActiveDocument
        Dim oSheet As Sheet
        oSheet = oDrawDoc.ActiveSheet
        If oDrawDoc.SelectSet.Count = 0 Then
            MsgBox("Please select at least one view.")
        Else
            Dim obj As Object
            For Each obj In oDrawDoc.SelectSet
                If TypeOf obj Is DrawingView Then
                    Dim oView As DrawingView = obj
                    oView.SetAutomatedCenterlineSettings()
                    Dim modelpane As BrowserPane = oDrawDoc.BrowserPanes.Item("Model")
                    For Each node As BrowserNode In modelpane.TopNode.BrowserNodes
                        Dim nodedef As BrowserNodeDefinition = node.BrowserNodeDefinition
                        If nodedef.Label = oSheet.Name Then
                            For Each viewnode As BrowserNode In node.BrowserNodes
                                Dim viewnodedef As BrowserNodeDefinition = viewnode.BrowserNodeDefinition
                                If viewnodedef.Label.StartsWith(oView.Name) Then
                                    Dim firstnode As BrowserNode = viewnode.BrowserNodes.Item(1)
                                    For Each secondnode As BrowserNode In firstnode.BrowserNodes
                                        For Each thirdnode As BrowserNode In secondnode.BrowserNodes
                                            Dim thirdnodedef As BrowserNodeDefinition = thirdnode.BrowserNodeDefinition
                                            If thirdnodedef.Label.StartsWith("3D") Then
                                                Dim sketch As Object = thirdnode.NativeObject
                                                If oView.GetVisibility(sketch) = False Then
                                                    thirdnode.Expanded = True
                                                End If
                                            Else
                                                For Each fourthnode As BrowserNode In thirdnode.BrowserNodes
                                                    Dim fourthnodedef As BrowserNodeDefinition = fourthnode.BrowserNodeDefinition
                                                    If fourthnodedef.Label.StartsWith("3D") Then
                                                        Dim sketch As Object = fourthnode.NativeObject
                                                        End If
                                                    End If
                                                Next
                                            End If
                                        Next
                                    Next
                                End If
                            Next
                        End If
                    Next
                    'Dim model As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
                    'For Each doc As _Document In model.AllReferencedDocuments
                    '    If TypeOf doc Is PartDocument Then
                    '        Dim pdoc As PartDocument = doc
                    '        Dim pdef As PartComponentDefinition = pdoc.ComponentDefinition
                    '        Dim threedsketch As Sketch3D
                    '        For Each threedsketch In pdef.Sketches3D
                    '            oView.SetIncludeStatus(threedsketch, True)
                    '        Next
                    '        threedsketch = Nothing
                    '        pdoc = Nothing
                    '    End If
                    '    doc = Nothing
                    'Next
                    'model = Nothing
                    'oView = Nothing
                End If
            Next
            obj = Nothing
        End If
    End Sub
Tags (1)
