- Mute
- Permalink
- Report
I have been adding to the code for setting automated center lines so that it also includes 3D sketches in the selected drawing view. Code went together fairly easy or so I thought. I tried different methods for doing this but the outcome is always the same. Not sure what I am missing or why it is behaving the way it is. Code is below and attached is a screen shot of the outcome. Using Inventor Pro 2018.3.1. Issue is the same on Windows 7 and Windows 10. In the image the far left detail is correct. The rest has the 3D sketch coming in not properly oriented. Any help would be appreciated.
Public Sub CMandCL(ThisApplication As Inventor.Application)
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
If oDrawDoc.SelectSet.Count = 0 Then
MsgBox("Please select at least one view.")
Else
Dim obj As Object
For Each obj In oDrawDoc.SelectSet
If TypeOf obj Is DrawingView Then
Dim oView As DrawingView = obj
oView.SetAutomatedCenterlineSettings()
Dim modelpane As BrowserPane = oDrawDoc.BrowserPanes.Item("Model")
For Each node As BrowserNode In modelpane.TopNode.BrowserNodes
Dim nodedef As BrowserNodeDefinition = node.BrowserNodeDefinition
If nodedef.Label = oSheet.Name Then
For Each viewnode As BrowserNode In node.BrowserNodes
Dim viewnodedef As BrowserNodeDefinition = viewnode.BrowserNodeDefinition
If viewnodedef.Label.StartsWith(oView.Name) Then
Dim firstnode As BrowserNode = viewnode.BrowserNodes.Item(1)
For Each secondnode As BrowserNode In firstnode.BrowserNodes
For Each thirdnode As BrowserNode In secondnode.BrowserNodes
Dim thirdnodedef As BrowserNodeDefinition = thirdnode.BrowserNodeDefinition
If thirdnodedef.Label.StartsWith("3D") Then
Dim sketch As Object = thirdnode.NativeObject
If oView.GetVisibility(sketch) = False Then
thirdnode.Expanded = True
End If
Else
For Each fourthnode As BrowserNode In thirdnode.BrowserNodes
Dim fourthnodedef As BrowserNodeDefinition = fourthnode.BrowserNodeDefinition
If fourthnodedef.Label.StartsWith("3D") Then
Dim sketch As Object = fourthnode.NativeObject
End If
End If
Next
End If
Next
Next
End If
Next
End If
Next
'Dim model As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
'For Each doc As _Document In model.AllReferencedDocuments
' If TypeOf doc Is PartDocument Then
' Dim pdoc As PartDocument = doc
' Dim pdef As PartComponentDefinition = pdoc.ComponentDefinition
' Dim threedsketch As Sketch3D
' For Each threedsketch In pdef.Sketches3D
' oView.SetIncludeStatus(threedsketch, True)
' Next
' threedsketch = Nothing
' pdoc = Nothing
' End If
' doc = Nothing
'Next
'model = Nothing
'oView = Nothing
End If
Next
obj = Nothing
End If
End Sub
- Mute
- Permalink
- Report
@Anonymous,
Can you please provide Inventor files to reproduce scenario? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Attached are the models. The code runs on a button click and I did notice a couple lines I forgot to change back. The line thirdnode.Expanded = True should be oView.SetIncludeStatus(thirdnode.NativeObject, True) and the other thirdnode.Expanded = True should be replaced with oView.SetIncludeStatus(fourthnode.NativeObject, True). See corrected code below. I noticed I have this issue with parts created within a weldment and not as a new part. Because I am referencing other parts to create the new part, it appears to throw off the 3D sketch when including it because of its orientation relative to the UCS. Not sure how to include it with respect to the weldment UCS.
Dim oSheet As Sheet
Else
Dim obj As Object
'oView.SetIncludeStatus(thirdnode.NativeObject, True)
End If
Else
fourthnode.Expanded = True
'oView.SetIncludeStatus(fourthnode.NativeObject, True)
End If
End If
Next
End If
Next
Next
End If
Next
End If
Next
' Next
' pdoc = Nothing
' End If
' doc = Nothing
'Next
'model = Nothing
oView = Nothing
End If
Next
obj = Nothing
End If
End Sub
- Mute
- Permalink
- Report
@Anonymous,
If the parts created inside weldment, sketch proxy need to create with reference occurrence (part) of weldment. Try below code to setIncludestatus of 3D sketch (it is working for attached weldment assembly).
Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument Dim oSheet As Sheet oSheet = oDoc.ActiveSheet Dim oView As DrawingView oView = oSheet.DrawingViews.Item(2) Dim oReferDoc As AssemblyDocument oReferDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument Dim occ As ComponentOccurrence occ = oReferDoc.ComponentDefinition.Occurrences.Item(3) Dim oDef As PartComponentDefinition oDef = occ.Definition Dim oProxy As Sketch3DProxy Call occ.CreateGeometryProxy(oDef.Sketches3D.Item(1), oProxy) Call oView.SetIncludeStatus(oProxy, True)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
Thank you! You gave me enough to get it working. I wanted to iterate through all occurrences and grab any and all 3D sketches to include. Below is the code.
Dim oSheet As Sheet
Else
Dim obj As Object
Dim i As Integer = 0
Dim model As _Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
If TypeOf model Is AssemblyDocument Then
Dim assymodel As AssemblyDocument = model
For Each occ As ComponentOccurrence In assymodel.ComponentDefinition.Occurrences
If occ.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
Dim oDef As PartComponentDefinition = occ.Definition
If oDef.Sketches3D.Count > 0 Then
For Each sketch As Sketch3D In oDef.Sketches3D
i += 1
Call occ.CreateGeometryProxy(oDef.Sketches3D.Item(i), oProxy)
Next
i = 0
End If
End If
Next
End If
End If
Next
End If
End Sub
