10-29-2018
08:47 AM
- Mute
- Permalink
- Report
10-29-2018
08:47 AM
You can certainly set something up in Vault to do this work automatically. You can also setup Vault to double check document properties among other things during a life-cycle change to make sure all the necessary info is filled out correctly:
I'll come up with an iLogic sample when I have enough time and post it here unless someone else beats me to it.
EDIT: You can also have the iLogic rule automatically trigger based on specific events instead of having to run the rule manually. For example, you'd run a rule like this either whenever the document is open or before the document gets saved.
