10-29-2018
05:51 AM
- Mute
- Permalink
- Report
10-29-2018
05:51 AM
Hi @Anonymous,
You can repurpose this rule of mine to do what you want:
Option Explicit On
Sub Main()
'current document
Dim doc as Inventor.Document = ThisDoc.Document
'Verify the current document has been saved.
If doc.FullFileName = "" Then
MessageBox.Show("This document must be saved first.")
Exit Sub
End If
'default folder
Dim FolderName As String = System.IO.Path.GetDirectoryName(doc.FullFileName)
Dim selectedfile As String = String.Empty
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Dwg files (*.dwg)|*.dwg|Excel files (*.xlsx)|*.xlsx|pdf files (*.pdf)|*.pdf|Inventor parts (*.ipt)|*.ipt|Inventor iFeatures (*.ide)|*.ide|XML Parameter files (*.xml)|*.xml|Step files (*.stp;*.step;*.stpz)|*.stp;*.step;*.stpz|Other files (*.*)|*.*"
oFileDlg.InitialDirectory = FolderName
oFileDlg.CancelError = True
oFileDlg.MultiSelectEnabled = True
Try
oFileDlg.ShowOpen()
selectedfile = oFileDlg.FileName
Catch
Return 'operation was cancelled by the user
End Try
AddReferences(doc, selectedfile)
End Sub
Public Sub AddReferences(ByVal odoc as Inventor.Document, ByVal selectedfile As String)
Dim oleReference As ReferencedOLEFileDescriptor
If selectedfile.Contains("|") Then ' we have multiple files selected.
Dim file As String() = selectedfile.Split("|")
For Each s as String in file
oleReference = odoc.ReferencedOLEFileDescriptors _
.Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
oleReference.BrowserVisible = True
oleReference.Visible = False
oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1)
Next
Else
.Add(selectedFile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
oleReference.DisplayName = Mid$(selectedFile, InStrRev(selectedFile, "\") + 1)
End If
End SubDepending on the version of Vault you have, you can also go further.
Please let me know if the above rule helps.
Alex.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
Alex Fielder
Inventor Expert
