- Mute
- Permalink
- Report
I have the code below. This code is to check for Hole features in a part.
If I have a pattern of a Solid Body then the code gives an error on the following line (if I have a pattern of any feature the code works fine):
If (TypeOf oRPF.ParentFeatures.Item(1) Is HoleFeature) Then
How can I check to see if I have a pattern of a Solid Body?
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oRectPatterns As RectangularPatternFeatures
Set oRectPatterns = oDef.Features.RectangularPatternFeatures
Dim oRPF As RectangularPatternFeature
For Each oRPF In oRectPatterns
If Not oRPF.Suppressed Then
‘do something
End If
End If
Next
- Mute
- Permalink
- Report
I actually found a workaround myself, by luck ![]()
If you use this code
For i = 1 To oRPF.ParentFeatures.Count
The Count returns 0 if you have a feature of a Solid Body.
So putting this code in front of the line where I got the error means I will never get to the line.
You could also use this code:
If oRPF.ParentFeatures.Count <> 0 Then
I will not put this as a solution because I would like to know the correct code for checking if a pattern is a pattern of a solid body.
- Mute
- Permalink
- Report
If solid body is used in rectangular pattern, then patternOfBody property of RectangularPatternFeatureDefinition will return true. For more details, refer below help documentation link.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-DD0D196A-A598-4EFD-8CD9-ADAEB25558
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
- Mute
- Permalink
- Report
Thank you for the reply Chandra. The link you provided does give me a 'Page not found' though.
I also do use Inventor 2018 at the moment.
- Mute
- Permalink
- Report
Check this,
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-DD0D196A-A598-4EFD-8CD9-ADAEB25558AB
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
