Hi @Curtis_Waguespack
I am working now.  For some reason, I had to change my Prompted Entry to <Unit Address> and update the code accordingly.  Once that was done, it worked perfectly.  Last thing I need to do it remove the :SheetNumber off the end of Prompted Entry in the TB.  If you have a quick code, that's great.  Otherwise, I will begin my search.
Thanks again for confirming!
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
