Curtis_Waguespack
Hi @Anonymous
Here is a quick update that uses the parent folder of the current file (it expects an assembly)....  as the "copy to" folder... and then this version places the component into the assembly.
I hope this helps.
Curtis
Imports System.IO
GetInput:
Six_Digit = InputBox("Enter 6 Digit number", "iLogic", 985236 )
If Six_Digit = "" Then
	Return
Else If Len(Six_Digit) <> "6" Then
	MessageBox.Show("Input must be 6 digits", "ilogic")
	Goto GetInput
End If
Dim oDoc As Document
Dim sFilename As String
'hard code path
oLibrary_Folder = "C:\TEMP\Library\"
Dim oFilenames() As String
oFilenames = System.IO.Directory.GetFiles(oLibrary_Folder, _
                      "*.*", SearchOption.AllDirectories )
For Each oFilename As String In oFilenames
	If oFilename.Contains(Six_Digit) Then
		Dim oOptions As Inventor.NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDoc = ThisApplication.Documents.OpenWithOptions(oFilename, oOptions, False)
		sFilename = oFilename
		Exit For
	End If
Next
If sFilename = "" Then
	MessageBox.Show("No matching libary file found.", "iLogic")
	Return
End If
iCounter = 0
'path from current file
'oProjectfolder = ThisDoc.Path & "\"
'path from current project file ( *.ipj)
oProjectfolder = _
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "\"
Dim oProject_Filenames() As String
oProject_Filenames = System.IO.Directory.GetFiles(oProjectfolder, _
'count existing project files
For Each oFilename As String In oProject_Filenames
		iCounter = iCounter + 1
	End If
Next
'increment counter
'find the postion of the last backslash in the path
FNamePos = InStrRev(sFilename, "\", -1)
'get the file name with the file extension
oName = Right(sFilename, Len(sFilename) - FNamePos)
'get the file name (without extension)
ShortName = Left(oName, Len(oName) - 4)
'get extension
oExt = Right(oName, 4)
If iCounter < 10 Then
	iCounter = "00" + CStr(iCounter)
ElseIf iCounter < 100 Then
	iCounter ="0" + CStr(iCounter)
Else
	iCounter = CStr(iCounter)
End If
oNewName = ShortName & "_" & iCounter
oPathandName = oProjectfolder & oNewName & oExt
'save new document
oDoc.SaveAs(oPathandName, True)
oDoc.Close
'[ Place Component
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create Matrix
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix
Call oMatrix.SetTranslation(ThisApplication.TransientGeometry.CreateVector(50, 50, 50), True)
'insert new occurence
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add( _
    oPathandName, oMatrix)
oOcc.grounded = False
ThisDoc.Document.SelectSet.Select(oOcc)
'MessageBox.Show("New file created: " & vbLf & oPathandName, "iLogic")
