Curtis_Waguespack
Hi @Anonymous,
This was put together as an example just from other examples from the past.
As for changing the project, most likely it could determine the project folder from the some info in the  current*.ipj file, or the current open file, or something along those lines... for example, you could just create this an an external rule, and then run it from an open assembly file that resides in the project folder, and the code would just look at the assembly file's location to determine the folder automatically.
Post back next week with more info, and i can likely help you make a quick update.
I hope this helps.
Curtis
