AlexFielder
The best thing you can do is share what you have code-wise.
As far as switching view-referenced models, the best answer I can find here is this:
https://forums.autodesk.com/t5/inventor-customization/how-to-replace-model-reference-in-idw-file/m-p... by @MechMachineMan :slightly_smiling_face:
EDIT: This rule of mine (should) also do this:
AddReference "System.Core"
AddReference "System.Linq"
Imports System.LINQ
Imports System.Collections.Generic
'doesn't run in iLogic - WHAT A SURPRISE!?!?!?
Private Sub Main()
            Dim sw As New Stopwatch()
            sw.Start()
            Dim rootFolder As String = IO.Path.GetDirectoryName(ThisApplication.ActiveDocument.FullFileName)
            Dim selectedfile As String = String.Empty
            Dim filedlg As Inventor.FileDialog = Nothing
            ThisApplication.CreateFileDialog(filedlg)
            filedlg.Filter = "txt files (*.txt)|*.txt|Other files (*.*)|*.*"
            filedlg.InitialDirectory = rootFolder
            filedlg.CancelError = True
            filedlg.MultiSelectEnabled = False
            Try
                filedlg.ShowOpen()
                selectedfile = filedlg.FileName
            Catch ex As Exception
                Return
            End Try
            Dim filelisttoreplace As New List(Of String)
            Dim filelisttosaveas As New List(Of String)
            Dim filereader As IO.StreamReader = Nothing
            filereader = My.Computer.FileSystem.OpenTextFileReader(selectedfile)
            Do While filereader.Peek >= 0
                filelisttoreplace.Add(filereader.ReadLine)
            Loop
            For Each filename As String In filelisttoreplace
                filelisttosaveas.Add(IO.Path.GetDirectoryName(filename) & "\" &
                                     IO.Path.GetFileNameWithoutExtension(filename) & ".dwg")
            Next
            If TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then
                For Each dwgfile As String In filelisttosaveas
                    Dim dwgdoc As DrawingDocument = ThisApplication.ActiveDocument
                    dwgdoc.SaveAsInventorDWG(dwgfile, False)
'                    Dim filedescr As FileDescriptor = dwgdoc.ReferencedFileDescriptors(1)
'                    Dim filetoreplace As String = (
'                        From f As String In filelisttoreplace
'                        Where IO.Path.GetFileNameWithoutExtension(f) = IO.Path.GetFileNameWithoutExtension(dwgdoc.FullFileName)).FirstOrDefault()
'                    If Not filetoreplace Is Nothing Then
'                        filedescr.ReplaceReference(filetoreplace)
'                        dwgdoc.Save()
'                    End If
                Next
            End If
            sw.Stop()
            MessageBox.Show("Operation took: " & sw.Elapsed.Seconds.ToString() & " seconds to complete.")
        End Sub
