BRLMCHKD
492 Views, 4 Replies
Work around to rename skeleton implemented in iLogic rule, by Copy Design
Hi.
Can someone give me an idea how to overcome the problem by Copy Design,  when the name of Skeleton therefore changes.  My problem is that the Skeleton is implemented in a iLogic Rule.  As it works for now I have to rename it manually, when I take Copy Design.
KR. BRLMCHKD
LukeDavenport
in reply to: BRLMCHKD
You have to lock the skeleton component name in the browser before using Copy Design. See this article:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/202020161-Inventor-2014-iLogic-Stabilise-Browse...
Luke
BRLMCHKD
in reply to: LukeDavenport
Hi Luke Smiley Happy
Thank you very muck for your answer.
But your solution still does'nt solve my problem. The reference in my iLogic rule on the idw, references to the original skeleton name .ipt
I have allready renamed the skeleton name in the browser of my iam, but "modelName" in my rule, do only work with
the original name of my skeleton.ipt
LukeDavenport
Could you just use one of the ModelDocumentName or ModelDocumentName (view) snippets of code, to get the actual current filename that has changed after the copy design operation, then us the same parameter function you're currently using after that?
Luke
SyntaxEditor Code Snippet
modelName = IO.Path.GetFileName(ActiveSheet.View("VIEW1").ModelDocument.FullFileName)
dwgParam = Parameter(modelName, "InjectNozRootDia")
BRLMCHKD
