johnsonshiue
Hi! This could be Windows related. Somehow Inventor 2016 no longer can start an Excel process. Try this and see if the theory is true. Open any existing part and go to Manage -> Create iPart. Does it work? If yes, it could be iLogic specific. If it does not work, it means Inventor cannot kick off an Excel process. You might need to re-register Inventor. Try the two followings.
1) Go to Control Panel -> Programs and Features -> find Inventor Pro 2016 -> right-click on it -> Uninstall/Change -> Repair Install.
Does the iLogic rule run now?
2) Go to command prompt -> cmd -> type "C:\Program Files\Autodesk\Inventor 2016\bin\Inventor.exe /install" and hit <Enter>. This will re-register Inventor 2016.
Does it run now?
Many thanks!
Software Test Engineer
