johnsonshiue
in reply to: chayman
Hi! I believe it can be done in iLogic. You can set any component IsActive() at any level within TLA to false. Please note that in order to do that, you will need to create a non-Master LOD at each level, including the top level. You can create "iLogic" LOD for example. Then you need to activate this iLogic LOD. After that, you will be able to set IsActive() to false.
Many thanks!
Software Test Engineer
