chayman
957 Views, 5 Replies
Suppressing sub-assembly components at the TLA using iLogic
Is there a way, using iLogic, that I can suppress parts in a subassembly at the top level assembly?
For example, I have a TLA called "PB". It already as a LoD named "iLogic".
Within the TLA there is a subassembly called "Wheel". What I want to do is suppress an ipt called "gusset" in the "Wheel" sub-assembly but from the TLA "PB".
Is this possible?
