- Mute
- Permalink
- Report
yes, with the API from inventor there is also a template delivered and installed.
this add in is to create your actual add in and is needed for this coding I posted.
because I am running inventor 2019 this will not work for you if you don't use the same version.
if the add in configuration is complete, this add in doesn't do anything, because there is no actual code in it.
at this moment it starts for you as programmer to add your specific codes.
so actually the inventor add in setup doesn't do anything till you add your buttons and codes and modules etc. etc.
you understand now?
Arthur Knoors
Autodesk Affiliations:
