bradeneuropeArthur
@Anonymous
that would be helpfull.
Do you understand what i mean and what the problem is from my side?
this is the code you need to place in your add in:
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' Initialize AddIn members.
            g_inventorApplication = addInSiteObject.Application
            ' Connect to the user-interface events to handle a ribbon reset.
            m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
            appevent = g_inventorApplication.ApplicationEvents            ' TODO: Add button definitions.
            f = New Form1(g_inventorApplication)
Private Sub appevent_OnActivateDocument(DocumentObject As _Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles appevent.OnActivateDocument If BeforeOrAfter = EventTimingEnum.kAfter Then ) Try f.Show() f.Text = DocumentObject.DisplayName 'f.Refresh() Catch ex As Exception 'MsgBox("g") End Try End If End Sub Private Sub appevent_OnOpenDocument(DocumentObject As _Document, FullDocumentName As String, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles appevent.OnOpenDocument If BeforeOrAfter = EventTimingEnum.kAfter Then Try f.Show() f.Text = DocumentObject.DisplayName 'f.Refresh() Catch ex As Exception MsgBox("h") End Try End If End Sub
Arthur Knoors
Autodesk Affiliations:
