- Mute
- Permalink
- Report
iPart indivdual drawings
I have an iPart factory with 612 different plates. I am using the iPart to control the length, width, and height of each in the table. What would the workflow be to quickly create an individual drawing per part? I want a material block on the drawing and LxWxH dims. I was recommended to come to the customization forum for an answer to this. What sort of rules or iLogic would I need to create this?
Thank,
Zach L
- Mute
- Permalink
- Report
You would need to step through the ipart table like this rule which checks whether Inventor can compute each row in the iPart/iAssembly table - FWIW I'm not sure I ever properly test the iAssembly section of this rule! Buyer-beware:
Sub Main()
CheckiPartTableForErrors()
End Sub
Sub CheckiPartTableForErrors()
Dim oErrorManager As ErrorManager = ThisApplication.ErrorManager
If TypeOf (ThisApplication.activedocument) Is partdocument Then
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oiPart As iPartFactory = oDoc.ComponentDefinition.iPartFactory
Dim oTop As BrowserNode = oDoc.BrowserPanes("Model").TopNode
Dim bHasErrorOrWarning As Boolean
Dim i As Integer
InventorVb.DocumentUpdate()
ThisApplication.SilentOperation = True
For i = 1 To oiPart.TableRows.Count 'use first 10 rows only for debugging purposes!
' Highlight the 3rd iPart table row which has invalid data
oTop.BrowserNodes("Table").BrowserNodes.Item(i).DoSelect
' Activate the iPart table row
Dim oCommand As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions("PartComputeiPartRowCtxCmd")
oCommand.Execute
ThisApplication.SilentOperation = False
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomallCmd").Execute
If oErrorManager.HasErrors Or oErrorManager.HasWarnings Then
MessageBox.Show(oErrorManager.LastMessage, "Title")
End If
Next i
MessageBox.Show("No errors shown = None found!", "Title")
ElseIf TypeOf (ThisApplication.activedocument) Is assemblydocument Then
Dim odoc As assemblydocument = ThisApplication.activedocument
Dim iAssy As iAssemblyFactory = odoc.componentdefinition.iassemblyfactory
Dim oTop As BrowserNode = odoc.BrowserPanes("Model").TopNode
Dim i As Integer
For rowIndex = 1 To iAssy.tablerows.count
oCommand.Execute
End If
Next
End If
End SubAnd working with the above you could (in theory) populate a new drawing template with a view that contains the currently active table row configuration.
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
- Mute
- Permalink
- Report
How would you go about changing the model references in iLogic? I am pretty new to using iLogic. I also have future projects that will be able to use the same iLogic it will just be a different iPart.
- Mute
- Permalink
- Report
I cant find a way to make the information in your code work with what i am trying to do. I am trying to change the model reference on a drawing. What i am trying to accomplish is step thru each member of the iPart on a drawing and save as part# then export it to a PDF. i already have the code for PDF.
- Mute
- Permalink
- Report
The best thing you can do is share what you have code-wise.
As far as switching view-referenced models, the best answer I can find here is this:
https://forums.autodesk.com/t5/inventor-customization/how-to-replace-model-reference-in-idw-file/m-p... by @MechMachineMan ![]()
EDIT: This rule of mine (should) also do this:
AddReference "System.Core"
AddReference "System.Linq"
Imports System.LINQ
Imports System.Collections.Generic
'doesn't run in iLogic - WHAT A SURPRISE!?!?!?
Private Sub Main()
Dim sw As New Stopwatch()
sw.Start()
Dim rootFolder As String = IO.Path.GetDirectoryName(ThisApplication.ActiveDocument.FullFileName)
Dim selectedfile As String = String.Empty
Dim filedlg As Inventor.FileDialog = Nothing
ThisApplication.CreateFileDialog(filedlg)
filedlg.Filter = "txt files (*.txt)|*.txt|Other files (*.*)|*.*"
filedlg.InitialDirectory = rootFolder
filedlg.CancelError = True
filedlg.MultiSelectEnabled = False
Try
filedlg.ShowOpen()
selectedfile = filedlg.FileName
Catch ex As Exception
Return
End Try
Dim filelisttoreplace As New List(Of String)
Dim filelisttosaveas As New List(Of String)
Dim filereader As IO.StreamReader = Nothing
filereader = My.Computer.FileSystem.OpenTextFileReader(selectedfile)
Do While filereader.Peek >= 0
filelisttoreplace.Add(filereader.ReadLine)
Loop
For Each filename As String In filelisttoreplace
filelisttosaveas.Add(IO.Path.GetDirectoryName(filename) & "\" &
IO.Path.GetFileNameWithoutExtension(filename) & ".dwg")
Next
If TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then
For Each dwgfile As String In filelisttosaveas
Dim dwgdoc As DrawingDocument = ThisApplication.ActiveDocument
dwgdoc.SaveAsInventorDWG(dwgfile, False)
' Dim filedescr As FileDescriptor = dwgdoc.ReferencedFileDescriptors(1)
' Dim filetoreplace As String = (
' From f As String In filelisttoreplace
' Where IO.Path.GetFileNameWithoutExtension(f) = IO.Path.GetFileNameWithoutExtension(dwgdoc.FullFileName)).FirstOrDefault()
' If Not filetoreplace Is Nothing Then
' filedescr.ReplaceReference(filetoreplace)
' dwgdoc.Save()
' End If
Next
End If
sw.Stop()
MessageBox.Show("Operation took: " & sw.Elapsed.Seconds.ToString() & " seconds to complete.")
End Sub![]()
Alex Fielder
Inventor Expert
