in reply to: Tom_Sturtevant
Hi Tom, thanks for your input! I made a quick script that runs the algorithm with your modifications as well as a screenshot of the output (See below). I believe it has the same issue as the one I described in my post. Once you get to the inner loop (j loop), in the code below, the PatternElement object has no information about the holes. Sure the outer loop (i loop) has the hole variable, but it isn't specific to the jth PatternElement. That is why it outputs all of the PatternElements twice, because there are two ParentFeatures. And I realized while making this script that the PatternElement object doesn't seem to know that there are two holes in each element. Which is why the PatternElement count is three and not six.
In the end I need the following information: There are 6 hole features in this pattern. Three of them are .25 in. diameter and their center points are x,y,z.... The other three are .75 in. diameter and their center points are x,y,z....
Sorry if this doesn't make sense. It is hard to explain.
Sample Code:
Sub Main()
	Dim part As Inventor.PartDocument = ThisDoc.Document
	Dim output As String = ""
	For Each pattern As RectangularPatternFeature In part.ComponentDefinition.Features.RectangularPatternFeatures
	    If Not pattern.Suppressed Then
	        output += "Found Pattern: " & pattern.Name & vbNewLine
			For i = 1 To pattern.ParentFeatures.Count
				output += "Parent Feature " & i & " of " & pattern.ParentFeatures.Count & ": " & pattern.ParentFeatures.Item(i).Name & vbNewLine
				If TypeOf pattern.ParentFeatures.Item(i) Is HoleFeature Then
					Dim hole As HoleFeature = pattern.ParentFeatures.Item(i)
					For j = 1 To pattern.PatternElements.Count
						If Not pattern.PatternElements.Item(j).Suppressed Then
							output += "Pattern Element " & j & " of " & pattern.PatternElements.Count & vbnewline
						End If
					Next j
				End If
			Next i
	    End If
	Next pattern
	MessageBox.Show(output)
End Sub
Output from sample code above:
