Tom_Sturtevant
Hi aneely_,
You will need to iterate through each patterned feature.  I have not tested this code but see if it gets you what you need.  Note that it now references mirror.ParentFeatures.Item(i).
For Each mirror As MirrorFeature In part.Definition.Features.MirrorFeatures
                If Not mirror.Suppressed Then
                                For i = 1 to mirror.ParentFeatures.count
                                                If (TypeOf mirror.ParentFeatures.Item(i) Is HoleFeature) Then
        Dim hole as HoleFeature = mirror.ParentFeatures.Item(i)
        For j = 1 to mirror.PatternElements.count
        dim element as FeaturePatternElement
        element = mirror.PatternElements.item(j)
        If Not element.Suppressed Then
        ' Get hole position
        ' Get hole size
        End If
        next j
                                                next i
                                End If
                End If
Next mirror
Hope that helps!
T.0.M.
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
