- Mute
- Permalink
- Report
@Anonymous
Could you provide me the Add-in setup in VB.net from your side.
Than I will paste my piece of code in it to make this work.
It works for me but the add in is made for Inventor 2019.
To let it work I need your add in for your version of Inventor.
Otherwise I can give you the steps you need to take to let this work.
let me know what you prefer.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
