- Mute
- Permalink
- Report
To my optic we should forget about the auto-macros in any environment, because of the issues related to them.
The only good way is start programming add ins based on the Save-events or other Events in inventor.
Only this way you are able to eliminate all the above or written problems....
If help is needed regarding this, I am willing to support.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
