' Get the Active part document.
Dim CurrDoc As Inventor.Document
Set CurrDoc = invApp.ActiveDocument
    Do While CurrDoc <> ThisDoc
        DoEvents    ' Yield to other processes.
        ' This is already set before!!! Set CurrDoc = invApp.ActiveDocument
    Loop
        ThisDoc.Save2 (True) 'Saving file at end of timer
Arthur Knoors
Autodesk Affiliations:
