@J-Camper
An short snippet and example of how to do it in VBA:
Public Sub AUTOSAVE()
' Connect to a running instance of Inventor.
Dim invApp As Inventor.Application
Set invApp = Thisapplication 'System.Runtime.InteropServices.Marshal.GetActiveObject _
                                            ("Inventor.Application")
' Get the Documents collection.
Dim oDocs As Inventor.Documents
Set oDocs = invApp.Documents
' Get the Active part document.
Dim ThisDoc As Inventor.Documents
Set ThisDoc = invApp.ActiveDocument
Set APE as Integer
APE =1
Set NOTE as Boolean
NOTE = True
Set BANANAN as string
BANANA = "This Banana"
For I-logic  all the sets are not neccessary...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Autodesk Affiliations:
