bradeneuropeArthur
This is possible with this kind of method..
Public Sub K()
Dim a As Application
Set a = ThisApplication
Dim b As PartDocument
Set b = a.ActiveDocument
Dim c As Camera
Set c = b.Views.Item(1).Camera
Do something with events here..........
c.Apply
End Sub
Arthur Knoors
Autodesk Affiliations:
