- Mute
- Permalink
- Report
When a user finishes a sketch the camera moves to a location that, most of the time, is troublesome and must be adjusted. Is there a way to modify this camera adjustment after finishing a sketch?
- Mute
- Permalink
- Report
does it help to uncheck the following options in the application options>
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Yes this worked great, thank you.
On a side note about customization, how difficult would it be for one to add the reorientation to face the camera at a sketch on creation but not on finishing? Also the camera reorienting on completion wouldn't be so bad if it zoomed to fit instead of the default location, adding parameters to modify this default view.
I've tried setting the home view to something more comfortable but it doesn't seem to use the home view as the location.
- Mute
- Permalink
- Report
This is possible with this kind of method..
Public Sub K() Dim a As Application Set a = ThisApplication Dim b As PartDocument Set b = a.ActiveDocument Dim c As Camera Set c = b.Views.Item(1).Camera Do something with events here.......... c.Apply End Sub
Arthur Knoors
