286 Views, 1 Reply
Design Accelerator Toolbar Tab
  Ive recently started using Inventor Pro 2019 and am having a difficult time figuring out where, or how, to get the Design tab function. Any help would be much appreciated.
bradeneuropeArthur
First enable the Design Accelerator Add in in the Add in manager.
then you will find it in the ribbon
Arthur Knoors
Autodesk Affiliations:
