marcin_otręba
in reply to: sgwilliams
This is sufficient way to accomplish it thru VBA... after determine status of file you can use .execute to checkin the files... if you want to do it without user interaction switch off check_in dialog window in inventor vault options..:"
If ThisApplication.CommandManager.ControlDefinitions.Item("VaultDataCardtop").Enabled = True And
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckouttop").Enabled = True Then
      Debug.Print "in vault(not checked out) check out possible"
End If
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultUndoCheckouttop").Enabled = True Then
       Debug.Print "in vault checked out"
End If
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckouttop").Enabled = False And
   ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckintop").Enabled = False Then
           Debug.Print "in vault locked (not possible to check out)"
End If
If ThisApplication.CommandManager.ControlDefinitions.Item("VaultDataCardtop").Enabled = False Then
          Debug.Print "not in vault"
End If,
