in reply to: andrew.tom.reynolds
Glad you found a solution that works for you.  However, you should be aware that this code will count all occurrences, even ones that are marked phantom or reference.  If there is ever the possibility of using reference parts, you should use the BOM functions shown in my example, or filter them out in your loop.
