08-29-2018
09:57 PM
- Mute
- Permalink
- Report
08-29-2018
09:57 PM
Try below iLogic code.
Dim path As String
path = "C:\Users\Public\2019\"
NolzPath = "C:\Users\Public\2019\NZLS\"
Dim oList As ArrayList
oList = GoExcel.CellValues(path + "ASSEMBLY GENERATOR.xlsx", "Nozzles", "O5", "O6")
'oList = GoExcel.CellValues(path + "ASSEMBLY GENERATOR.xlsm", "Nozzles", "O2", "O3")
Dim FlangeFolder As String
For Each name In oList
Dim oNewAssy As AssemblyDocument
oNewAssy = ThisApplication.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject)
oNozSize = Split(name, "-")(0)
'MessageBox.Show(oNozSize, "SIZE")
oNozSch = Split(name, "-")(1)
'MessageBox.Show(oNozSch, "SCH")
oNozLen = Split(name, "-")(2)
'MessageBox.Show(oNozLen, "LEN")
oFlgTypeRtng = Split(name, "-")(3)
'MessageBox.Show(oFlgTypeRtng, "")
oNozServ = Split(name, "-")(4)
'MessageBox.Show(oNozServ, "SERVICE")
''remove 1st 5 charachters from file name - ie. NOZLC
oNozSize = Right(oNozSize, Len(oNozSize) - 5)
'MessageBox.Show(oNozSize,"size")
'create values for the rating and type of flange. ie RF150 is RF and 150
oFlgType = Left(oFlgTypeRtng, Len(oFlgTypeRtng) - 3)
oFlgRtng = Right(oFlgTypeRtng, Len(oFlgTypeRtng) - 2)
'MessageBox.Show(oFlgType, "FLNG TYPE")
'MessageBox.Show(oFlgRtng,"FLNG RATING")
Try
oNozSize = (oNozSize).Replace("/", "_")
Catch
End Try
Dim oMatrix As Matrix
oMatrix = ThisApplication.TransientGeometry.CreateMatrix()
FlangePath = "Tube & Pipe:Fittings:Flanges"
If oFlgType = "RF"
Select Case oFlgRtng
Case "150"
FlangeFolder = "ASME B16.5(21)\"
Case "300"
FlangeFolder = "ASME B16.5(23)\"
Case "600"
FlangeFolder = "ASME B16.5(25)\"
Case "900"
FlangeFolder = "ASME B16.5(26)\"
End Select
Axis = "False"
InsertDis = .5
Else If oFlgType = "WN"
Case "150"
FlangeFolder = "ASME B16.5(38)\"
Case "300"
FlangeFolder = "ASME B16.5(41\"
Case "600"
FlangeFolder = "ASME B16.5(43)\"
Case "900"
FlangeFolder = "ASME B16.5(44)\"
End Select
Axis = "True"
InsertDis = .125
End If
'MessageBox.Show(FlangeFolder, "Title")
'\\\ here are the paths where the flanges and pipe are saved at.
PipePath = "C:\Users\dfitting\Documents\Inventor\Content Center Files\R2019\en-US\ASME B36.10M(1)\" & "PIPEC" & oNozSize & "-" & oNozSch & "-" & oNozLen & ".ipt"
FlangePath = "C:\Users\dfitting\Documents\Inventor\Content Center Files\R2019\en-US\" & FlangeFolder & "FLNGC" & oNozSize & ".ipt"
Dim componentA As ComponentOccurrence
componentA = oNewAssy.ComponentDefinition.Occurrences.Add(PipePath, oMatrix)
componentA.Name = "Pipe"
Dim componentB As ComponentOccurrence
componentB = oNewAssy.ComponentDefinition.Occurrences.Add(FlangePath, oMatrix)
componentB.Name = "Flange"
Dim oFace As Face
Dim oFlangeFace_Pipe As Face
Dim oInsideFace_Pipe As Face
For Each oFace In componentA.Definition.SurfaceBodies.Item(1).Faces
If oFace.InternalName = "{D2F0749E-CD50-6222-9FD3-82A95937E2C7}" Then
oFlangeFace_Pipe = oFace
ElseIf oFace.InternalName = "{34E025BE-9958-2F5D-43C5-4A4EDECF143F}" Then
oInsideFace_Pipe = oFace
End If
Next
Dim oFlangeFace_Flange As Face
For Each oFace In componentB.Definition.SurfaceBodies.Item(1).Faces
If oFace.InternalName = "{F5A66A0A-37CA-1154-750F-3BE821568F9F}" Then
oFlangeFace_Flange = oFace
Exit For
End If
Next
Dim oFaceProxy_pipe As FaceProxy
If Not oFlangeFace_Pipe Is Nothing Then
Call componentA.CreateGeometryProxy(oFlangeFace_Pipe, oFaceProxy_pipe)
Else
Exit Sub
End If
Dim oFaceProxy_Flange As FaceProxy
If Not oFlangeFace_Flange Is Nothing Then
Call componentB.CreateGeometryProxy(oFlangeFace_Flange, oFaceProxy_Flange)
Else
Exit Sub
End If
Call oNewAssy.ComponentDefinition.Constraints.AddInsertConstraint(oFaceProxy_pipe, oFaceProxy_Flange, False, InsertDis)
Dim xzPlaneA As WorkPlane
xzPlaneA = componentA.Definition.Workplanes.Item("XZ Plane")
Dim xzPlaneA_proxy As WorkPlaneProxy
componentA.CreateGeometryProxy(xzPlaneA,xzPlaneA_proxy)
Dim xzPlaneB As WorkPlane
xzPlaneB = componentB.Definition.Workplanes.Item("XZ Plane")
Dim xzPlaneB_proxy As WorkPlaneProxy
componentB.CreateGeometryProxy(xzPlaneB, xzPlaneB_proxy)
Call oNewAssy.ComponentDefinition.Constraints.AddMateConstraint(xzPlaneA_proxy,xzPlaneB_proxy,"0")
Dim oCustomProp As Inventor.Property
Try
oNewAssy.PropertySets.Item(4).Item("Custom Prop").Value = "Custom Value"
Catch
oCustomProp = oNewAssy.PropertySets.Item(4).Add("Custom value", "Custom Prop")
End Try
oNewAssy.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "123456"
oNewAssy.PropertySets.Item("Design Tracking Properties").Item("Description").Value = "Description"
Try
name = (name).Replace("/", "_")
Catch
End Try
Call oNewAssy.SaveAs(NolzPath + name + ".iam", False)
Call oNewAssy.Close
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
