chandra.shekar.g
in reply to: DFitting
@DFitting,
Try below iLogic code to add content center file to assembly file. It is considered for below example.
Sub PlaceContentCenterPart()
    ' Set a reference to the active assembly document.
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the ContentCenter object.
    Dim oContentCenter As ContentCenter
    oContentCenter = ThisApplication.ContentCenter
    ' Get the content node (category) "Fasteners:Bolts:Hex Head"
    Dim oContentNode As ContentTreeViewNode
    oContentNode = oContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Bolts").ChildNodes.Item("Hex Head")
    ' Get the "ISO 4015" Family object.
    Dim oFamily As ContentFamily
    For Each oFamily In oContentNode.Families
        If oFamily.DisplayName = "ISO 4015" Then
            Exit For
        End If
    Next
    ' Create a member based on the first row of the family.
    Dim Error1 As MemberManagerErrorsEnum
    Dim strContentPartFileName As String
    Dim strErrorMessage As String
    strContentPartFileName = oFamily.CreateMember(1, Error1, strErrorMessage)
   ' Dim oMat As Matrix
   ' oMat = ThisApplication.TransientGeometry.CreateMatrix
    ' Insert an instance of the content center member in the assembly.
    'Call oDoc.ComponentDefinition.Occurrences.Add(strContentPartFileName, oMat)
    ' Set a reference to the transient geometry object.
    Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
' Create a matrix.
Dim oMatrix As Matrix
oMatrix = oTG.CreateMatrix
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
'place an instance of the component
'in this case at 0,0,0
'positioned at the co-ordinates
oMatrix.SetTranslation(oTG.CreateVector(0, 0, 0))
oOccurrence = oAsmCompDef.Occurrences.Add(strContentPartFileName, oMatrix)
oOccurrence.Grounded = False
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
