DFitting
in reply to: MjDeck
I'm having a similar issue with the new
Components.AddContentCenterPart
 Ive got it to place the pipe in, but I am only able to place in the content centers default length, ie. 50" long
as we know, Inventor default content center has the PL parameter set to an expression of [0.001;;;50] which I know is where the 50 is coming from. I feel like I'm missing a step, or maybe it's not possible at the time to place an expressional part such as a pipe.
This is some test code, it is placing the 1st component but when I uncomment the 2nd one @ 20" it won't place it.
SyntaxEditor Code Snippet
Dim componentA = Components.AddContentCenterPart("occNameA", "Tube & Pipe:Conduits:Pipes", "ASME B36.10M Pipe",
	                                        {"Size_Designation","3 - Schedule 40" ,"PL",50},
	                                        position := Nothing, grounded := False,
	                                        visible := True, appearance := Nothing)
'Dim componentB = Components.AddContentCenterPart("occNameB", "Tube & Pipe:Conduits:Pipes", "ASME B36.10M Pipe",
'	                                        {"Size_Designation","3 - Schedule 40" ,"PL",20},
'	                                        position := Nothing, grounded := False,
'	                                        visible := True, appearance := Nothing)
