clutsa
in reply to: Maxim-CADman77
Would any of this info help you?
Sub Test()
Dim app As Application
Dim Doc As Document
Dim CompDef As ComponentDefinition
Dim PartType As String
Set app = ThisApplication
Set Doc = app.ActiveDocument
Set CompDef = Doc.ComponentDefinition
iPartFac = CompDef.IsiPartFactory
iPartMem = CompDef.IsiPartMember
Select Case Doc.DocumentType
Case Is = DocumentTypeEnum.kPartDocumentObject
    PartType = "Part File"
Case Is = DocumentTypeEnum.kDrawingDocumentObject
    PartType = "Drawing File"
'Case Is .... keep going with these
End Select
End Sub
Those may be easier then what you're doing.
I know you'll have to have some error trapping but that should be a good start.
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
