Maxim-CADman77
1198 Views, 8 Replies
Logical type of Active Inv Doc (if TryCast is a best bet)
I'm playing around with iLogic trying to find best way to get logical type of active document.
I mean those logical types:
3D-models
  • Generic Part
  • Generic Assembly
  • Generic Drawing
  • iPart Factory
  • iPart Member
  • iAssy Factory
  • iAssy Member
2D-drawings
  • Generic Drawing (not based on any 3D-model)
  • Exploded View Drawing
  • (Single) Part Drawing
  • (Single) Assembly Drawing
  • Multi-configuration Part Drawing (based on iPart Member or iPart Factory)
  • Multi-configuration Assembly Drawing (based on iAssy Member or iAssy Factory)
I 've achieved my goal to about 75%. There are problems with Generic Drawing (object not set to an instance of an object) and both multi-config drawings (I'm a bit confused by depth of object tree and can't find how to get object types for i- factories and members).
My current version of code is:
Dim partDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
Dim assyDoc As AssemblyDocument = TryCast(ThisDoc.Document, AssemblyDocument)
Dim drwDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
Dim MsgBody As String
If (partDoc IsNot Nothing) Then
	oCompDef=partDoc.ComponentDefinition
	If (oCompDef.iPartFactory IsNot Nothing) Then
		MsgBody="iPart Factory"
	Else If (oCompDef.iPartMember IsNot Nothing) Then
		MsgBody="iPart Member"
	Else
		MsgBody="Generic Part"
	End If
Else If (assyDoc IsNot Nothing) Then
	oCompDef=assyDoc.ComponentDefinition
	If (oCompDef.iAssemblyFactory IsNot Nothing) Then
		MsgBody="iAssy Factory"
	Else If (oCompDef.iAssemblyMember IsNot Nothing) Then
		MsgBody="iAssy Member"
	Else
		MsgBody="Generic Assembly"
	End If
Else If (drwDoc IsNot Nothing) Then
	Dim ModelExt As String = TryCast (IO.Path.GetExtension(ThisDrawing.ModelDocument.FullFileName).ToLower, String)
	If ModelExt=".ipn" Then
		MsgBody="Exploded view drawing"
	Else If ModelExt=".ipt" Then
		MsgBody="Part drawing"
		' If ??? Then MsgBody="Multi-config Part drawing"
	Else If ModelExt=".iam" Then
		MsgBody="Assembly drawing"
		' If ??? Then MsgBody="Multi-config Assy drawing"
	Else
		MsgBody="Generic Drawing"
	End If
Else
	MsgBody="UnknownDoc"
End If
MsgBox (MsgBody,,"Type of active doc is:")
Can somebody help me with this, please
Please vote for Inventor-Idea Text Search within Option Names
