1333 Views, 14 Replies
iLogic Sketch Redefine.
I've tried to use "sketch.redefine" syntax according to steps pre described here:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
but It doesn't work and I don't know why.
Below the snippet of code I've made:
SyntaxEditor Code Snippet
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oDef As PartComponentDefinition
oDef = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oDef.Sketches.Item(1)
Sketch.Redefine(oSketch.Name,"P�aszczyzna XY","Punkt �rodkowy","X",AxisIsX := True,NaturalAxisDirection:= True)
The idea is to check and redefine existing sketch on the XY plane.
Thanks in advance for any help.
Tomek
