martinhoos
1235 Views, 3 Replies
How to drive constraints
Hello together,
i need your your help. I like to drive, move and rotate constraints with ilogic. The following code rotates all of the driven constraints. The code shouldt be drive only a constraint named "move1" vertical from 0 to 155 and rotated an other constraint named "rotate1" from 0 to 45 degree. Is that possible?
And another question: The code rotates clockwise from 0 to 45 degree. Is it possible to rotate from 0 to -45?
Thanks in advance
Regards Martin
Sub Main()
    Dim assyDoc As AssemblyDocument
    assyDoc = ThisApplication.ActiveDocument
    Dim oConstraint As AssemblyConstraint
    For Each oConstraint In assyDoc.ComponentDefinition.Constraints
        If oConstraint.DriveConstraintSettings.IsInitialized Then
            With oConstraint.DriveConstraintSettings
				.StartValue = 0
                .EndValue = 45
                .GoToStart
                .PlayForward
'                .StartValue = 0
'                .EndValue = 150
'                .GoToEnd
'                .PlayReverse
			End With
        End If
    Next
End Sub
