- Mute
- Permalink
- Report
Hi Alex,
The aim is I'm looking for the solution of bigger iLogic rule / problem.
I've created the rule which is responsible for export of BOM to the excell file.
But this is not only simple export. In fact we need the data to be ready for print as a template we use.
So the rule sends BOM (row by row - missing content center parts or parts marked as "purchased") to the excell file
and then starts the macro which is responsilbe for sorting data to looks as we would like to.
Because at the end I would like to equipped all Inventor user with the rule, I'd like to be sure we are able to avoid any error situation.
Right now the rule works quite fine but there are two problematic situations:
1) When there are any missing parts (unresolved parts) within the assembly. Specialy when we share whole assemblies between users and some parts are missing during that process.
2) When the view representation is not set up as main
Below You can see the complete rule right now i have:
SyntaxEditor Code Snippet
Dim oDoc As Inventor.Document oDoc = ThisApplication.ActiveDocument 'At first we're chcecking if opened file is an assembly or single part file. For single part system is running other rule. If oDoc.DocumentType <> kAssemblyDocumentObject Then If oDoc.DocumentType = kPartDocumentObject Then UserChoice0 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia dla pojedy�czej cz�ci?", "iLogic",MessageBoxButtons.YesNo) If UserChoice0 = vbNo Then Exit Sub Else iLogicVb.RunExternalRule("Karta Ci�cia Cz��") Exit Sub End If End If End If 'We're checking if the assembly file was already saved. FilePath = ThisDoc.Path If FilePath = "" Then MessageBox.Show("Plik z�o�enia nie zosta� zapisany!" _ & vbLf & " " _ & vbLf & "Zapisz plik, nast�pnie uruchom regu�� ponownie.", "iLogic") Exit Sub End If 'Notification for user to be sure he would like to run the rule. UserChoice2 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia?" _ & vbLf & " " _ & vbLf & "Upewnij si� �e wszystkie niezb�dne dane zosta�y uzupe�nione.", "iLogic",MessageBoxButtons.YesNo) If UserChoice2 = vbNo Then Exit Sub End If 'Input box to get user name Opracowal = InputBox("Kart� Ci�cia Opracowa�:", "iLogic","Tomasz Pa�asz") Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oDoc.ComponentDefinition 'Below a peace of code to check if the detail representation - main is set up. Currently it doesn't work I don't know why? 'Dim oLOD As LevelOfDetailRepresentation 'Try 'oLOD = oDoc.RepresentationsManager.LevelOfDetailRepresentations.Item("G��wna").Activate(True) 'Catch 'MessageBox.Show("Wyst�pi� problem z uaktywnieniem reprezentacji widoku - G��wna", "iLogic") 'Exit Sub 'End Try 'Below a peace of code to check if there are any unresolved parts within the assembly. If there are any it would be 'impossible to open BOM Dim oRefFile As FileDescriptor For Each oRefFile In oDoc.File.ReferencedFileDescriptors Dim AsmFilePath As String = oRefFile.FullFileName If Not System.IO.File.Exists(AsmFilePath) Then MessageBox.Show("Prawdopodobnie otwarte z�o�enie zawiera nierozwi�zane komponenty." _ & vbLf & "Upewnij si� �e w z�o�eniu nie ma nierozwi�zanych komponent�w." _ & vbLf & "Nast�pnie uruchom regu�� ponownie", "iLogic") Exit Sub Else End If Next 'Now main part - which is responsible for BOM file export into an Excell file. After that the excell macro starts to sort the data within an excell file. Dim oBOM As BOM oBOM = oAsmCompDef.BOM oBOM.PartsOnlyViewEnabled = True Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Tylko Cz�ci") oBOMView.Sort("Part Number", True) oBOMView.Renumber(001) Dim oBOMRow As BOMRow 'The rule checks for file path where an excell file is located. Dim Filename As String = "C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\Karta Ci�cia Wz�r.xlsm" '<---- TUTAJ ZMIE� �CIE�K� ! 'If an excell file is already opened the rule will try to close it. Try ObjXL = GetObject(Filename) ObjXL.Application.Quit Catch End Try GoExcel.Open(Filename,"Arkusz2") i=3 'The rule is counting total number of rows in the BOM j=0 For Each oBOMRow In oBOMView.BOMRows If oBOMRow.BOMStructure <> 51973 Then Dim oCompDef As ComponentDefinition oCompDef = oBOMRow.ComponentDefinitions.Item(1) FullFileName = oCompDef.Document.FullFileName Pozycja=InStrRev(FullFileName,"\", -1) NazwaModelu=Right(FullFileName,Len(FullFileName)-Pozycja) NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number") Opis=iProperties.Value(NazwaModelu, "Project", "Description") 'For every row in the BOM we're trying to catch custom iProperties vaulues Try Nazwa=iProperties.Value(NazwaModelu, "Custom", "Nazwa") Catch Nazwa="" End Try Try Rodzaj=iProperties.Material(NazwaModelu) Catch Rodzaj="" End Try Try Wymiar=iProperties.Value(NazwaModelu, "Custom", "Wymiar") Catch Wymiar="" End Try Try Uwagi=iProperties.Value(NazwaModelu, "Custom", "Uwagi") Catch Uwagi="" End Try Ilosc=oBOMRow.Totalquantity GoExcel.CellValue("B" & i)=Opis GoExcel.CellValue("C" & i)=NumerCzesci GoExcel.CellValue("D" & i)=Nazwa GoExcel.CellValue("E" & i)=Rodzaj GoExcel.CellValue("F" & i)=Wymiar GoExcel.CellValue("H" & i)=Uwagi GoExcel.CellValue("G" & i)=Ilosc i=i+1 j=j+1 End If Next 'Based on total rows number the rule takes proper no. of excell sheet pages and sends it to the excell file. '[ Select Case j Case 1 To 12 Iloscstr = 1 Case 13 To 24 Iloscstr = 2 Case 25 To 36 Iloscstr = 3 Case 37 To 48 Iloscstr = 4 Case 49 To 60 Iloscstr = 5 End Select '] Try Artykul = iProperties.Value("Project", "Stock Number") Catch End Try GoExcel.CellValue("A1")=iProperties.Value("Project", "Part Number") GoExcel.CellValue("B1")= Iloscstr GoExcel.CellValue("A2")= "Nr Art." & " " & Artykul GoExcel.CellValue("D1")=iProperties.Value("Project", "Description") GoExcel.CellValue("G1")= Opracowal GoExcel.DisplayAlerts = False GoExcel.Save GoExcel.Close 'Here the rule fires up the macro. Dim ExApp As Object ExApp = CreateObject("Excel.Application") Try 'Tutaj dodano fragment. For Each wb As Object In ExApp.workbooks If UCase(wb.fullname) = UCase(filename) Then 'wb.Save wb.Close Exit For End If Next Catch Finally excelApp = Nothing End Try 'Tutaj ko�czy si� dodany fragment. ExApp.workbooks.Open (Filename) ExApp.Application.Run ("KartaCieciaWzor") ExApp.Visible = False ExApp = Nothing Dim Numer As String 'The rule tries to check if the end excell file was properly created and saved. Numer = "C:\Users\t.palasz\Desktop\Karty Ci�cia\" & iProperties.Value("Project", "Part Number") & ".xlsx" '<---- TUTAJ ZMIE� �CIEK� If System.IO.File.Exists(Numer) Then UserChoice3 = MessageBox.Show ("Karta Ci�cia zosta�a wygenerowana pomy�lnie!" & vbLf & " " & vbLf & "Czy chcesz otworzy� Kart� Ci�cia?", "iLogic",MessageBoxButtons.YesNo) If UserChoice3 = vbYes Then ThisDoc.Launch(Numer) Exit Sub Else Exit Sub End If Else MessageBox.Show("Upss... Co poszo nie tak!", "iLogic") Exit Sub End If
