- Mute
- Permalink
- Report
Hi Guys,
I'm looking for some solution which allows me to check for all unresolved components within the assembly and delete them if there are any.
Is it possible to create the iLogic rule to do that?
Thanks in advance for help.
Best Regards
Tomek
- Mute
- Permalink
- Report
From this page: http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-0123304B-EC33-4430-B4F1-CBF225CB5B8F
comes this example iLogic Rule (Adapted slightly, because at the page above the code was VBA):
Public Sub Main()
Dim oFile As File = ThisApplication.ActiveDocument.File
Call ProcessReferences(oFile)
End Sub
Private Sub ProcessReferences ( ByVal oFile As File )
Dim oFileDescriptor As FileDescriptor
For Each oFileDescriptor In oFile.ReferencedFileDescriptors
Debug.Print oFileDescriptor.FullFileName
If Not oFileDescriptor.ReferenceMissing Then
' Since the ReferenceMissing has returned False, the ReferencedFile will return a File
' Recurse unless this is a foreign file reference
If Not oFileDescriptor.ReferencedFileType = kForeignFileType Then
Call ProcessReferences(oFileDescriptor.ReferencedFile)
End If
End If
Next
End SubIn theory you could use the same approach with a simple modification, instead of just checking whether the "oFileDescriptor.ReferenceMissing", you could do this:
If oFileDescriptor.ReferencedDocument = nothing then 'delete oFileDescriptor End If
Of course, I have to ask why you want to delete unresolved references at all? Since in doing so, it will likely mean you'll end up with broken Assemblies and referencing drawings. Is it a dataset you inherited/don't have the time/money to fix?
Alex Fielder
Inventor Expert
https://github.com/alexfielder/
LinkedIn - Github Inventor Extension Server - Bonkers polygon iLogic thing
Top ten iLogic Tips - API Shortcut In Google Chrome - Assembly Extrusion Example
- Mute
- Permalink
- Report
Hi, this is created in vba, switch the commented line to actually delete the occurence
Sub DeleteUnresolvedFiles()
Dim oFile As Inventor.File
Set oFile = ThisApplication.ActiveDocument.File
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
oDoc.Save
Dim oDocDef As AssemblyComponentDefinition
Set oDocDef = oDoc.ComponentDefinition
Call ProcessReferences(oFile, oDoc, oDocDef)
End Sub
Private Sub ProcessReferences(ByVal oFile As Inventor.File, oDoc As AssemblyDocument, oDocDef As ComponentDefinition)
If Not oFileDescriptor.ReferencedFileType = FileTypeEnum.kForeignFileType Then
Call ProcessReferences(oFileDescriptor.ReferencedFile, oDoc, oDocDef)
End If
Else
Dim oComp As ComponentOccurrence
For Each oComp In oDocDef.Occurrences
If oComp.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName = oFileDescriptor.FullFileName Then
MsgBox (oFileDescriptor.FullFileName & vbCrLf & oFileDescriptor.RelativeFileName)
'oComp.Delete
End If
Next oComp
End If
Next
End Sub
please feel free to "kudos"
- Mute
- Permalink
- Report
Hi Alex,
The aim is I'm looking for the solution of bigger iLogic rule / problem.
I've created the rule which is responsible for export of BOM to the excell file.
But this is not only simple export. In fact we need the data to be ready for print as a template we use.
So the rule sends BOM (row by row - missing content center parts or parts marked as "purchased") to the excell file
and then starts the macro which is responsilbe for sorting data to looks as we would like to.
Because at the end I would like to equipped all Inventor user with the rule, I'd like to be sure we are able to avoid any error situation.
Right now the rule works quite fine but there are two problematic situations:
1) When there are any missing parts (unresolved parts) within the assembly. Specialy when we share whole assemblies between users and some parts are missing during that process.
2) When the view representation is not set up as main
Below You can see the complete rule right now i have:
SyntaxEditor Code Snippet
Dim oDoc As Inventor.Document oDoc = ThisApplication.ActiveDocument 'At first we're chcecking if opened file is an assembly or single part file. For single part system is running other rule. If oDoc.DocumentType <> kAssemblyDocumentObject Then If oDoc.DocumentType = kPartDocumentObject Then UserChoice0 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia dla pojedy�czej cz�ci?", "iLogic",MessageBoxButtons.YesNo) If UserChoice0 = vbNo Then Exit Sub Else iLogicVb.RunExternalRule("Karta Ci�cia Cz��") Exit Sub End If End If End If 'We're checking if the assembly file was already saved. FilePath = ThisDoc.Path If FilePath = "" Then MessageBox.Show("Plik z�o�enia nie zosta� zapisany!" _ & vbLf & " " _ & vbLf & "Zapisz plik, nast�pnie uruchom regu�� ponownie.", "iLogic") Exit Sub End If 'Notification for user to be sure he would like to run the rule. UserChoice2 = MessageBox.Show ( "Czy chcesz wygenerowa� Kart� Ci�cia?" _ & vbLf & " " _ & vbLf & "Upewnij si� �e wszystkie niezb�dne dane zosta�y uzupe�nione.", "iLogic",MessageBoxButtons.YesNo) If UserChoice2 = vbNo Then Exit Sub End If 'Input box to get user name Opracowal = InputBox("Kart� Ci�cia Opracowa�:", "iLogic","Tomasz Pa�asz") Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oDoc.ComponentDefinition 'Below a peace of code to check if the detail representation - main is set up. Currently it doesn't work I don't know why? 'Dim oLOD As LevelOfDetailRepresentation 'Try 'oLOD = oDoc.RepresentationsManager.LevelOfDetailRepresentations.Item("G��wna").Activate(True) 'Catch 'MessageBox.Show("Wyst�pi� problem z uaktywnieniem reprezentacji widoku - G��wna", "iLogic") 'Exit Sub 'End Try 'Below a peace of code to check if there are any unresolved parts within the assembly. If there are any it would be 'impossible to open BOM Dim oRefFile As FileDescriptor For Each oRefFile In oDoc.File.ReferencedFileDescriptors Dim AsmFilePath As String = oRefFile.FullFileName If Not System.IO.File.Exists(AsmFilePath) Then MessageBox.Show("Prawdopodobnie otwarte z�o�enie zawiera nierozwi�zane komponenty." _ & vbLf & "Upewnij si� �e w z�o�eniu nie ma nierozwi�zanych komponent�w." _ & vbLf & "Nast�pnie uruchom regu�� ponownie", "iLogic") Exit Sub Else End If Next 'Now main part - which is responsible for BOM file export into an Excell file. After that the excell macro starts to sort the data within an excell file. Dim oBOM As BOM oBOM = oAsmCompDef.BOM oBOM.PartsOnlyViewEnabled = True Dim oBOMView As BOMView oBOMView = oBOM.BOMViews.Item("Tylko Cz�ci") oBOMView.Sort("Part Number", True) oBOMView.Renumber(001) Dim oBOMRow As BOMRow 'The rule checks for file path where an excell file is located. Dim Filename As String = "C:\Users\Public\Documents\Autodesk\Inventor 2018\Templates\Karta Ci�cia Wz�r.xlsm" '<---- TUTAJ ZMIE� �CIE�K� ! 'If an excell file is already opened the rule will try to close it. Try ObjXL = GetObject(Filename) ObjXL.Application.Quit Catch End Try GoExcel.Open(Filename,"Arkusz2") i=3 'The rule is counting total number of rows in the BOM j=0 For Each oBOMRow In oBOMView.BOMRows If oBOMRow.BOMStructure <> 51973 Then Dim oCompDef As ComponentDefinition oCompDef = oBOMRow.ComponentDefinitions.Item(1) FullFileName = oCompDef.Document.FullFileName Pozycja=InStrRev(FullFileName,"\", -1) NazwaModelu=Right(FullFileName,Len(FullFileName)-Pozycja) NumerCzesci=iProperties.Value(NazwaModelu, "Project", "Part Number") Opis=iProperties.Value(NazwaModelu, "Project", "Description") 'For every row in the BOM we're trying to catch custom iProperties vaulues Try Nazwa=iProperties.Value(NazwaModelu, "Custom", "Nazwa") Catch Nazwa="" End Try Try Rodzaj=iProperties.Material(NazwaModelu) Catch Rodzaj="" End Try Try Wymiar=iProperties.Value(NazwaModelu, "Custom", "Wymiar") Catch Wymiar="" End Try Try Uwagi=iProperties.Value(NazwaModelu, "Custom", "Uwagi") Catch Uwagi="" End Try Ilosc=oBOMRow.Totalquantity GoExcel.CellValue("B" & i)=Opis GoExcel.CellValue("C" & i)=NumerCzesci GoExcel.CellValue("D" & i)=Nazwa GoExcel.CellValue("E" & i)=Rodzaj GoExcel.CellValue("F" & i)=Wymiar GoExcel.CellValue("H" & i)=Uwagi GoExcel.CellValue("G" & i)=Ilosc i=i+1 j=j+1 End If Next 'Based on total rows number the rule takes proper no. of excell sheet pages and sends it to the excell file. '[ Select Case j Case 1 To 12 Iloscstr = 1 Case 13 To 24 Iloscstr = 2 Case 25 To 36 Iloscstr = 3 Case 37 To 48 Iloscstr = 4 Case 49 To 60 Iloscstr = 5 End Select '] Try Artykul = iProperties.Value("Project", "Stock Number") Catch End Try GoExcel.CellValue("A1")=iProperties.Value("Project", "Part Number") GoExcel.CellValue("B1")= Iloscstr GoExcel.CellValue("A2")= "Nr Art." & " " & Artykul GoExcel.CellValue("D1")=iProperties.Value("Project", "Description") GoExcel.CellValue("G1")= Opracowal GoExcel.DisplayAlerts = False GoExcel.Save GoExcel.Close 'Here the rule fires up the macro. Dim ExApp As Object ExApp = CreateObject("Excel.Application") Try 'Tutaj dodano fragment. For Each wb As Object In ExApp.workbooks If UCase(wb.fullname) = UCase(filename) Then 'wb.Save wb.Close Exit For End If Next Catch Finally excelApp = Nothing End Try 'Tutaj ko�czy si� dodany fragment. ExApp.workbooks.Open (Filename) ExApp.Application.Run ("KartaCieciaWzor") ExApp.Visible = False ExApp = Nothing Dim Numer As String 'The rule tries to check if the end excell file was properly created and saved. Numer = "C:\Users\t.palasz\Desktop\Karty Ci�cia\" & iProperties.Value("Project", "Part Number") & ".xlsx" '<---- TUTAJ ZMIE� �CIEK� If System.IO.File.Exists(Numer) Then UserChoice3 = MessageBox.Show ("Karta Ci�cia zosta�a wygenerowana pomy�lnie!" & vbLf & " " & vbLf & "Czy chcesz otworzy� Kart� Ci�cia?", "iLogic",MessageBoxButtons.YesNo) If UserChoice3 = vbYes Then ThisDoc.Launch(Numer) Exit Sub Else Exit Sub End If Else MessageBox.Show("Upss... Co poszo nie tak!", "iLogic") Exit Sub End If
- Mute
- Permalink
- Report
Hi @Anonymous,
Thanks for the detailed explanation and code sample.
I can see now why you want to remove unresolved components. I agree that if it's going to cause the exported BOM process to fail then you'd be correct to remove them.
BUT (And it's a big but!), it would seem to me to be a better question/solution if you were able to address why you are seeing unresolved components.
Typical reasons for this are (and I'm sure someone else will add to this list if I miss anything):
- Assemblies not saved in consistent network paths i.e. some users have Z:\path\to\assembly whereas others may have \\servername\zdriveroot\path\to\assembly or a mixture of both.
- Users creating assemblies locally on C: and not sharing all files.
- Users creating assemblies locally and not using/being aware of "Pack & Go" to grab all referenced files.
- (and by no means least) users working on assemblies locally and not setting the correct project file.
- Inconsistent naming of part files (user A creates a new part called "widget", user then creates another part called "widget" using a different project file and (after sharing the assembly) when a different user opens the assembly they get prompted as to which they want to use and choose neither.
So really this boils down to:
a) Do you use Vault? All versions provide unique naming checks which can prevent users checking in multiple parts called "widget" or whatever. Vault also allows enforcement of a common project file for all users.
b) Are your team trained sufficiently that they're aware of the company's unique naming/path conventions?
c) Is any of ^ documented (for new/existing users)?
Since you're here and asking for help on this, there are steps you can take whilst you get a thru c above sorted out.
The first of which would be put together (or update) a document showing what is stored where on your network as well as the reason for it's importance in getting paths correct (point them to this post if necessary).
Second, I would think about changing your iLogic rule above such that when it finds an unresolved file to flag to the user the points I noted above, such that they can set the correct project file, check they received a complete pack & go and/or are using the correct file paths etc. etc.
Third, if you have users (even especially those who are self-taught!) who haven't been trained (or trained recently) I would heartily recommend you seek out the services of your local Autodesk reseller who will be more than happy to help.
Full disclosure: I work for a reseller here in the UK, so have trained Inventor users on both the main product, as well as iLogic in the past and the unresolved file problem typically stems from the issues I touched on above.
Apologies for the wall of text, but I hope it gives you food for thought.
Cheers,
Alex.
Alex Fielder
Inventor Expert
- Mute
- Permalink
- Report
PS. I would recommend that if you insist on continuing to delete unresolved files, that you wrap the whole method in a transaction, thereby giving the user a chance to undo the whole thing, otherwise (if there are a lot) it'll be a painful process to sit and click "Undo" repeatedly:
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oAssemblyDocument, "Clean up unresolved files")
Try
'Do Stuff
trans.Commit()
Catch 'any errors
trans.Abort()
End Try![]()
Alex Fielder
Inventor Expert
- Mute
- Permalink
- Report
Hi Alex,
Thanks for fast reply and a bounch of information.
In fact our team use the Vault aplication and we're working only on single project file.
So problem with unresolved files occures really rarely.
But because I would like to be sure my rule works 100% reliably before I'll redistribute it to all users I need to check if it would work with all our files.
Right now it looks not bad but there are still two problems I've mantioned above.
One with unresolved files (most of them are parts from content center library - If anybody uses different from project library). I'm wondering about using the snippet of code given by frederic but I'm not sure which part I can cut to adapt the code to iLogic syntax.
Second one is problem with switching the view representation into main.
Now I have a piece of code wich should be able to do that but it's not working.
Dim oLOD As LevelOfDetailRepresentation Try oLOD = oDoc.RepresentationsManager.LevelOfDetailRepresentations.Item("G��wna").Activate(True) Catch MessageBox.Show("Wyst�pi� problem z uaktywnieniem reprezentacji widoku - G��wna", "iLogic") Exit Sub End Try
- Mute
- Permalink
- Report
Hi Frederic,
I've made some small adjusments to adopt syntax to iLogic and now it works great.
Thanks a lot for help.
Best Regards
- Mute
- Permalink
- Report
@Anonymous @frederic.vandenplas I have the need to delete unresolved references as well, can you share the ilogic code you made to do this?
- Mute
- Permalink
- Report
Please try this snippet:
Dim oFile As Inventor.File oFile = oAsmDoc.File Dim oFileDescriptor As FileDescriptor For Each oFileDescriptor In oFile.ReferencedFileDescriptors If Not oFileDescriptor.ReferenceMissing Then If Not oFileDescriptor.ReferencedFileType = FileTypeEnum.kForeignFileType Then End If Else Dim oComp As ComponentOccurrence For Each oComp In oAsmCompDef.Occurrences If oComp.ReferencedDocumentDescriptor.ReferencedFileDescriptor.FullFileName = oFileDescriptor.FullFileName Then oComp.Delete
I hope You'll find it helpful
Regards
Tomek
