donaldleigh
513 Views, 1 Reply
Find Sheet Metal Part in Assembly
Hi guys
I have the 1st rule that returns the type of file. this works great
but the 2nd rule can't find the sheet metal part. It only recognizes it as a part. I know its because of the line is looking at the Assembly doc and not the sheet metal part
"SyntaxEditor Code Snippet
If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then
But I'm not sure how to change this.
Donald
Inventor 2014
Rule 1
Dim doc As Document = ThisDoc.Document
If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then
'Drawing File
MessageBox.Show("Drawing", "Title")
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then
'Part & Sheet Metal File
        'Sheet Metal File
        MessageBox.Show("Sheet Metal", "Title")
    Else
        'Part File
        MessageBox.Show("Part", "Title")
    End If
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject  Then
'Assembly File
MessageBox.Show("Assembly", "Title")
End If
iLogicVb.UpdateWhenDone = True
Rule 2
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all Of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
    If oOccurrence.DefinitionDocumentType = kDrawingDocumentObject Then
    Else If oOccurrence.DefinitionDocumentType = kPartDocumentObject Then
        Else
        End If
    Else If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
    End If
Next
InventorVb.DocumentUpdate()
in reply to: donaldleigh
Hi Try this,
Dim openDoc As Inventor.Document
Dim docFile As Inventor.Document
Dim docFName As String
openDoc = ThisApplication.ActiveDocument
For Each docFile In openDoc.AllReferencedDocuments
    If docFile.DocumentType = kPartDocumentObject And docfile.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'sheet metal part'
        docFName = (docFile.FullFileName)
        MessageBox.Show(docFName & " is a sheet metal part", "Parts that are Sheet Metal")
    End If
Next
