448 Views, 5 Replies
osheet
i have some coding and keep getting the error "oSheet" is not declared coding below
SyntaxEditor Code Snippet
'START
Quit=MessageBox.Show("Do you wish to run this rule?","title",MessageBoxButtons.YesNo)
If Quit=7 Then
Exit Sub
End If
       TableCheck:'------------------------------------------------------'---------------start finding the table----------------'------------------------------------------------------
For i = 1 To oSheet.CustomTables.Count
    TableTitle = oSheet.CustomTables.Item(i).Title
    If TableTitle = "Operating Conditions" Then
        'Remember the table number for editing section
        TableNr = i
        'If table found jump to edit section
        Goto EditTable
    End If
Next
'------------------------------------------------------'---------------end finding the table----------------'------------------------------------------------------
'CreateTable:'------------------------------------------------------'---------------start creating the table---------------'------------------------------------------------------' Set the column titles
oTitles = New String(){"Item", "Description"}'
' Create the custom table
oCustomTable = oSheet.CustomTables.Add("Operating Conditions", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _
                                    2, 11, oTitles,oContents, oColumnWidths)
'------------------------------------------------------'---------------finish creating the table---------------'------------------------------------------------------'edit the table by restarting the check routine
Goto TableCheck
EditTable:'------------------------------------------------------'---------------start editing the table---------------'------------------------------------------------------'Get the name Of the first model in the drawing
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
'MessageBox.Show(modelName, "ilogic")'
'------------------------------------------------------'---------------finish editing the table---------------'------------------------------------------------------
R.Mabery
Hi bpWallis17,
You haven't declared oSheet.  Is your entire rule shown or have you cut some out of it?
The code doesn't know what oSheet is.  More than likely, you need something like this above what you've shown.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawDoc.Sheets.Item(1)
This is assuming you want to work on the first sheet of the document.
Randy Mabery
Applications Expert
IMAGINiT Technologies
in reply to: R.Mabery
i now get this message after adding your bit in "Object reference not set to an instance of an object."
R.Mabery
Is this your entire code?
Randy Mabery
Applications Expert
yes it is i assuming theres something missing ?
R.Mabery
'START
If Quit=7 Then
Exit Sub
End If
Dim oSheet As Sheet
        TableNr = i
        GoTo EditTable
    End If
Next
GoTo TableCheck
Hi, it's working fine here.  The only place I see a possible issue is if your drawing doesn't have a model in it.  It could fail as currently written if there is no drawing view of a model to get in that last line.
Randy Mabery
Applications Expert
