chandra.shekar.g
in reply to: avincent
@avincent,
Custom tolerances of chamfer note are available through FormattedChamferNote API as XML tags as shown below.
<Distance1 Precision='3' AlternatePrecision='0' UpperTolerance='0.000000' LowerTolerance='0.000000' ToleranceType='kSymmetricTolerance' TolerancePrecision='2' ToleranceAlternatePrecision='2'></Distance1> X <Angle Precision='2' UpperTolerance='0.000000' LowerTolerance='0.000000' ToleranceType='kSymmetricTolerance' TolerancePrecision='2'></Angle> Chamfer
VBA code:
Sub Main()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oChamferNote As ChamferNote
    Set oChamferNote = oSheet.DrawingNotes.ChamferNotes.Item(1)
    Debug.Print oChamferNote.FormattedChamferNote
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
