cmcconnell
in reply to: JaneFan
Here is the problem: When I have adate property in the titleblock which is driven by the model property, and this property is empty (01/01/1601 in the back ground). When I use my rule to copy properties from my idw to my model, any date value that is empty shows up in the titleblock as 01/01/1601. To manually fix this, i need to go check and uncheck the date in the model property editor.
I added that line to my rule so that it checks the model property for a value. If that value is 01/01/1601, it does not copy the 01/01/1601 from the idw. Which seems to satisfy that part of the issue.
The part which I am now having difficulty with: If I clear a date in my idw property editor and push my properties back to the model, the 01/01/1601 is copied to the model and then displayed in the tblock.
Mechanix Design Solutions inc.
