chandra.shekar.g
in reply to: avincent
@avincent,
Try below VBA code to determine values and tolerances of chamfer notes. Usually, tolerances will return in integer values which can mapped to respective LinearPrecisionEnum using below Inventor 2019 help documentation link.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-FBD80F0D-AF01-47AA-BC61-8DB782ACAE0D
Sub Main()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oChamferNote As ChamferNote
    Set oChamferNote = oSheet.DrawingNotes.ChamferNotes.Item(1)
    Debug.Print oChamferNote.Text
    Dim oStyle As DimensionStyle
    Set oStyle = oChamferNote.DimensionStyle
    Dim oLinear As LinearPrecisionEnum
    oLinear = oStyle.LinearPrecision
    Debug.Print "Linear precision : " & oLinear
    Dim oAngular As LinearPrecisionEnum
    oAngular = oStyle.AngularPrecision
    Debug.Print "Angular precision : " & oAngular
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
