- Mute
- Permalink
- Report
Hello @Anonymous there are a few things you could try to clear out the Customize data.
The easiest would be to go to Manage > iLogic > Delete All Rules.
Another less intrusive way would be to try to RMB top panel > Reset Ribbon.
I don't think that will work, next would be to sign in as a different user profile and see if the macros are still there just for a test to see what might be holding them there, if it is the registry or user profile.
The most likely fix would be to export all of your settings and then perform Reset Utility.
Interesting links that might help:
delete rule with internal macro vba?
ModTheMachine: Removing VBA Document Projects From Inventor Files
Please select the Accept as Solution button if a post solves your issue or answers your question.
Kelly Young
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
