Public Sub main()
Dim a As Application
 a = ThisApplication
Dim CmdMan As ControlDefinition
 CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckout")
If CmdMan.Enabled = True Then
CmdMan.Execute 'CmdMan.Execute2 (True)
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
