- Mute
- Permalink
- Report
Check if part is on workspace if not then download from vault (iLogic)
Is there an iLogic code that I can implement that checks if a part is on my workspace. If not then download this file from the vault
- Mute
- Permalink
- Report
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim CmdMan As ControlDefinition
Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckout")
If CmdMan.Enabled = True Then
CmdMan.Execute
'CmdMan.Execute2 (True)
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Arthur Knoors
- Mute
- Permalink
- Report
I got the next error when I run this rule in iLogic:
Rule Compile Errors in Rule0, in afvoerbuis test samenstelling.iam
Error on Line 4 : Let- en Set-assignment instructions are no longer supported.
Error on Line 7 : Let- en Set-assignment instructions are no longer supported.
- Mute
- Permalink
- Report
Public Sub main()
a = ThisApplication
CmdMan.Execute 'CmdMan.Execute2 (True)
End If
End Sub
Arthur Knoors
- Mute
- Permalink
- Report
I've deleted the part in my workspace and runned the rule you wrote.
But he doesn't download the file from the vault (see attachment).
- Mute
- Permalink
- Report
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Is your Vault activated within inventor?
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
try it in a different way:
For VBA:
Public Sub main()
set a = ThisApplication
set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
MsgBox "will be checked out"
End If
End SubFor I logic
Public Sub Main()
a = ThisApplication
MsgBox ("will be checked out")
End If
End SubRegards,
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
- Mute
- Permalink
- Report
Still doesn't work. So I've checked the assy out of the vault. I saved the assy to my workspace and all the parts are in the directory. Now I start the assy out of my workspace and I delete a part in this directory on the workspace. If I run the rule the part doesn't return in my workspace directory.
