I think this might give you what you need.  I quickly prototyped it in VBA but it can easily be converted to be VB.NET compatible, which is what iLogic uses.
Public Sub AutoProject()
    '  a reference to the currently active document.
    ' This assumes that it is a part document.
    Dim oPart As PartDocument
    Set oPart = ThisApplication.ActiveDocument
    '  a reference to the component definition.
    Dim oDef As PartComponentDefinition
    Set oDef = oPart.ComponentDefinition
    Dim planeEnt As Object
    Set planeEnt = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select plane to create the sketch.")
    Dim oSketch As PlanarSketch
    Set oSketch = oDef.Sketches.Add(planeEnt)
    Dim sketchName As String
    sketchName = InputBox("Give your new sketch a name", "Sketch Name", "Enter Sketch Name Here")
    oSketch.name = sketchName
    Dim feat As PartFeature
    Set feat = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Select the feature to project")
    ' Iterate over the faces that were created by the feature.
    Dim usedEdges As ObjectCollection
    Set usedEdges = ThisApplication.TransientObjects.CreateObjectCollection
    Dim featFace As Face
    For Each featFace In feat.faces
        ' Iterate over the edges in the faces.
        Dim featEdge As Edge
        For Each featEdge In featFace.Edges
            ' Check to see if this edge has already been projected.
            Dim checkEdge As Edge
            Dim isUsed As Boolean
            isUsed = False
            For Each checkEdge In usedEdges
                If featEdge Is checkEdge Then
                    isUsed = True
                    Exit For
                End If
            Next
            If Not isUsed Then
                ' Project the edge onto the sketch.
                Call oSketch.AddByProjectingEntity(featEdge)
                ' Add this edge to the list of used edges.
                Call usedEdges.Add(featEdge)
            End If
        Next
    Next
End Sub
Brian Ekins
