dgreatice
Dim oApp As Application
Dim oPD As PartDocument
Dim oPCD As PartComponentDefinition
Dim oSurfBody As SurfaceBody
oApp = ThisApplication
oPD = oApp.ActiveDocument
oPCD = oPD.ComponentDefinition
For Each oSurfBody In oPCD.SurfaceBodies
if Sliderail = "No" then
if oSurfBody.Name = "Sliderail, round" or oSurfBody.Name = "Sliderail, Square" then
oSurfBody.Visible = False
else
osurfbody.visible = true
End if
ElseIf Sliderail = "Round" Then
If oSurfBody.Name = "Round" Then
oSurfBody.Visible = True
else
end if
ElseIf Sliderail = "Square" Then
If oSurfBody.Name = "Square" Then
else
End if
End if
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
