657 Views, 7 Replies
iLogic: control the visibility of one body
If I were to control the visibility of one body, how would I write the code for that
It's a yes or no function I'm looking for
Parameter (Parameter name: Sliderail)
  Yes
  No
Bodyname
  Sliderail, round
dgreatice
try this:
Version:1.0 StartHTML:00000145 EndHTML:00002241 StartFragment:00000294 EndFragment:00002209 StartSelection:00000294 EndSelection:00000294SyntaxEditor Code Snippet
Dim oApp As Application
Dim oPD As PartDocument
Dim oPCD As PartComponentDefinition
Dim oSurfBody As SurfaceBody
oApp = ThisApplication
oPD = oApp.ActiveDocument
oPCD = oPD.ComponentDefinition
For Each oSurfBody In oPCD.SurfaceBodies
    If oSurfBody.Name = "Sliderail" Then
        oSurfBody.Visible = False
    End If
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
in reply to: dgreatice
The parameter will be a "text" parameter with yes or no. Will this affect the code?
dgreatice
You can add more condition
        if Sliderail = "Yes" then
oSurfBody.Visible = True
else
end if
End If Next
What if you have the paramter options and 2 bodies?
  No   (...None of the 2 bodies are vissible)
  Round   (Sliderail, round is visible)
  Square   (Sliderail, Square is visible)
Bodynames
  Sliderail, round
  Sliderail, square
dgreatice
if Sliderail = "No" then
if oSurfBody.Name = "Sliderail, round" or oSurfBody.Name = "Sliderail, Square" then
else
osurfbody.visible = true
End if
ElseIf Sliderail = "Round" Then
If oSurfBody.Name = "Round" Then
else
end if
ElseIf Sliderail = "Square" Then
If oSurfBody.Name = "Square" Then
else
End if
End if
Next
Awesome. Thank You!
What if I had 3 extra bodies that should be visible at all times. How would that affect the code
Lets just call them
body1
body2
body3
dgreatice
you can try, let me know if there are error.
